kevinh
Hi there,
I recently picked up a fairly well used Kity 636 thickness planer. It was supposed to be a bit of a stop-gap till I could raise the funds to afford something with a bit more grunt and I was hoping I'd get a couple of years out of it.
But lo and behold last week during a moderatley long session (motor running for about an hour) there was magic smoke and a bad smell. Turned it off straight away, gave it the once over to check for anything obvious and when I tried to restart it there was a low hum and no movement.
I've been told that the armature needs replacing and that it's not the biggest job in the world. My question is though, if I repair it will the same thing just happen again the next time I'm running the planer for a while? Should I cut my loses and get something with a better rated motor? Are these just very light-duty machines for hobbiests?
The annoying thing is I was singing it's praises to myself just before it cut out as it was planing some very figured maple very little tear-out...
So do I repair it or sell it or both?
Thanks!
Thanks!
