Kity 613 guide bearings
MG1977
21 Mar 2014
Bristol
Having gone ahead with the eBay Kity 613 purchase I'm pretty happy with the quality of the unit, table and wheels in particular. I'm looking forward to my tuffsaw blades arriving and hope to get these bearings sorted before hand.
Does anyone have any experience of replacing guide bearings on the 613?
I've attached some photos that show the rear thrust bearing and side bearing plates. As you can see the thrust bearing is pretty shot, the cover has been removed and there appear to be two chips to the cover plate.
What I can't figure out is how to remove the bearing so it can be replace...dimensions suggest its a 6200 bearing, but if anyone could confirm that would be great.
With the side guides, do these just run against the blade? Won't the heat generated shorten the life of the blade? I was wondering how easy would it be to replace these spinning disks with some blocks of hardwood, lignum vitea is often used for bearings I'm told.
Any input you can offer is appreciated. This is my first bandsaw and so I'd like to try and get it right if I can.
Michael
    60.6 KB
    58.7 KB
just place the shaft in a loose vice
rest the bearing on the jaws
and tap the shaft through with drift
that deals with the bearing
press on a new one pressing on the inner race only
there should be numbers on the old bearing but if you post the 3 sizes we can confirm the size
the side thrust bearings run with a small clearence so no appreciable heat should be generated
Ian
Cheers Ian, I tried hitting the shaft through the bearing but it doesn't seem to want to budge!
Does it definitely just slide out, it couldn't be tapped and screwed onto the threaded shaft? Have you done this on you own kity?
Also, sorry to ask, but what do you mean by tap with drift?
It will be tight perhaps a 1lb hammer onto a drift ( length of steel slightly smaller diameter than your bearings id )
definately not screwed
and perhaps tap is wrong sometimes bashing with all your force is nessesary
Ian
