Jones and shipman pillar drill
Blacksmithmanoffire
New member
6 Jan 2020
Peterborough
Hello I'm not sure if I'm posting this in the correct group but iv got my hands on a jones and shipman pillar drill and am trying to find out if and where I can get new parts for example a new belt the one on it looks very old and I'm not sure how long its gonna last also when I drill any hole 10mm or wider the chuck pulls itself out its tapered hole not sure if that means it's a bit worn it is an old drill but works really well and I'd just like to keep it going any help or advice would be much appreciated thank you
AES
18 Feb 2011
Switzerland, near Basel
I don't know this particular drill, but the advice that often crops up on here is to take the old belt with you to your local motor factors and they should be able to find a new replacement to suit, off the shelf - and often at a lower price than from the drill manufacturer.
If the chuck (and it's adaptor??) are slipping out of the taper in the quill, then the first thing is to check that both the tapers (male and female) are PERFECTLY clean - even just a small piece of metal swarf can affect the fit. Cleaning the male taper is easy enough, but it's usually a bit of a faddle to clean the female - I use a bit of tissue wrapped around my little finger then dampened with a SMALL drop of acetone and wiggle it all the way round and round and up into the top of the quill.
If that doesn't stop the problem, are you sure the "tang" (used for removing the chuck and adaptor) is locating into the slot at the top of the quill (I'm assuming here that your drill uses a tapered drift through a slot at the top of the quill, rather than the pair of external "U" wedges for removing the chuck and adaptor seen on some pillar drills)?
If neither of the above apply I guess it's POSSIBLE (but rather unlikely IMO) that the male taper is so badly worn that it's not seating inside the female properly, in which case a new adaptor will be needed to screw into the "top" of the chuck (not expensive, try ArecEurotrade for example - usual disclaimers).
And if none of the above apply, then I DUNNO, sorry!
HTH
TFrench
6 Jul 2015
Leics
Is the belt flat or vee? How old a drill are we talking? The last J&S drill I bought was an absolute nail. I had to admit defeat and weighed it in - poor thing had been farmered to death. As AES said, make sure the tapers are clean - is it just the chuck that slips out or have you tried it with morse taper drills as well? If its the male taper, bin it and get a fresh one, they're not expensive. If its the female I have had success removing a burr by using a MT2 reamer (this was a lathe, so I had the tailstock to keep it aligned.)
