Stephen H
New member
Pillar drill riser handle.
I decided to put a table onto my pillar drill as the one that came with it was quite small and designed for engineers. I use mine mainly for woodworking so needed a bigger area and a fence. I looked on YouTube for ideas and came across some but there were quite a lot of American ones who seem to have money to burn especially when it came to how the bed winds up and down and one looked like a recycled back axel from a quad bike (where would you get stuff like that in the UK
So I came up an English version using bits out of my garage!
I removed the handle and replaced it with a large nut (18mm) which I filed out the thread part until it fit the shaft on the drill where the handle had been, I then drilled and tapped ones of the flats, tapped the hole and fitted a grub screw. I got an 18mm socket, knuckle joint + extension bar. I had a piece that I think came out of an old wrench which was a 1/2ā square at both ends and fitted the sockets of the extension bar, I created a round bit on one end to fit the handle . I then made some simple brackets to hold everything together and in the place I wanted it - Job done and it works great
