barkwindjammer
is there such a thing?, something that could be used outdoors as well as in, and is PVA really pants?
Olly...no, good stuff :wink: - RobOPJ":1wrpz1tk said:Does Titebond III leave a thick glue line? Just something I heard.
joiner_sim":1buoovpn said:This stuff is great! Can be used in marine applications!
"cascamite" for those who know it by name.
Brian Jackson":1du4yee9 said:
devonwoody":1445yxsb said:jimi43, your comments (not claiming invalid) surprise me, I have used Titebond3 for some years now (much of it with my strip designs) and I have never had a failure, joint or laminating wise.
Perhaps you purchased your glue at the wrong time of year, I like to buy around July and store indoors all the year
, I reckon if anyone purchased any glue this week it will have come from a cold and icy warehouse somewhere, perhaps that might be the problem.
Polyvinyl acetate (PVA). (White Glue) A one part emulsion with high bond strength. It can be used on all woods, soft, hard, chipboards, plywood, etc. A good general purpose woodwork adhesive for indoor use only. There is an external quality made but I would not rate it greater than MR. - Evo Stick Resin W ~ INT
Aliphatic resin glues (Yellow Glue) - Possible has an upper hand on PVA especially for the brown hardwoods. It provides a strong initial tack with fast setting to help reduce the clamping time. Offers excellent 'sand ability' and is unaffected by finishes. Titebond - INT
KeithS":w9bx5qze said:Hi
Take a look at titebond, been useing titebond2 recently and can recomend it for both inside and out side use.
Keith
Joints":2nnushae said:KeithS":2nnushae said:Hi
Keith
Dont glue it in the cold though!
jimi43":1ci9ad0k said:Titebond is not a PVA...it is an aliphatic resin glue (yellow glue in the States):
IMHO and borne out by testing...the relative strength of the PVA and Titebond range shows that Titebond Original has the lead in all parameters except waterproof aspect. Hence my preference for Original where water is not an issue.
