After much deliberation I decided to buy myself an early Chrimbo prezzy, so off I went with credit card in hand looking for my first Bandsaw!!!
Unfortunately with Christmas fast approaching, my funds were running a little low, so I set myself a limit of £300 - £400
What I ended up going for was the iTECH MJ344C from Scott & Sargeants @ £239 + £60 Delivery, and after taking delivery of my new baby, I thought I’d do a little review for you guys and gals.
Weighing in at an impressive 140kgs I’m very glad I had a forklift and a sack barrow to unload this baby and get it where I wanted
All in all its a very nice little bandsaw for the money, it has a nice size cast iron table, and bearing guides instead of the cool blocks that I would have expected on a saw of this price. It also has a 200mm cut height (untested), but looking forward to finding out :wink: .
The only problems I had with the saw, were the bearing guides not being parallel to the blade, which was fixed by using a thin piece of metal as a shim to level thing up, and that seems to have worked fine.
(sorry about the focus )
The other problem was the NVR switch. For some reason the saw would only run with the green button pressed and held on, as soon as I let go of the button the saw would switch off!! Very annoying to say the least, and after a couple of hours after trying everything I could think of to fix the problem to no avail, I decided it might be best to give s&s a call before I did my usual trick and made thing ten time worse!!
2 Days later my new switch arrives and everything is hunky dorri.
All in all after a few teething problems I’m very pleased with the iTECH and very pleased with Scott & Sargeant as a whole.
Now all I have to do is get myself a nice new blade, and get butchering wood!!!
Regards
Andy
Regards
Andy
