is Tormek diamond truing device worth having?
nicksmith
6 Dec 2005
South Yorkshire
Hello,
Just a simple question.
My Tormek stone could do with a light truing. Is the diamond device the best way of going about this?
Thanks, Nick :?:
Chris Knight
14 Jan 2004
SE London - NW Kent
Nick,
It is the only way I have trued mine so I can't compare it with another dresser, like the ones with a broad face. It seems to me they might be better inasmuch the Tormek dresser leaves grooves if you are not careful and whilst they come out with care or after a couple of plane irons have been ground, they are a bit annoying.
Having asid this the Tormek thing does work.
nicksmith
6 Dec 2005
South Yorkshire
Thank you Chris,
Please will you tell me, where might I see a broad one (I don't think APTC have them - or do they!)
Thanks,
Nick
jasonB
26 Nov 2004
Surrey
I've only ever used the Tormek one on mine and then onlt a couple of times, the grooves can soom be knocked off with the stone.
Hereare some other dressers made for bench grinders, flat type second from bottom. Would have to make sure you held it at right angles to the wheel.
Jason
Alf
22 Oct 2003
Up the proverbial creek
Dunno, perhaps there's a special Tormek one too, but here. I finally prised open the wallet to get one, and it's good.
Cheers, Alf
paulm
IG paulm_outdoors
25 Sep 2005
North Hampshire
Hi Nick,
Definitely worth getting the diamond dresser specific for the Tormek as it trues the stone dead parallel to the toolrest bar, meaning that your sharpening of plane irons, chisels etc get better results from the smooth surface of the stone and keeps the ground edge square to the blade.
I use a normal diamond dresser about a half inch wide on the normal grinder and it's fine for that but wouldn't be much good on the Tormek stone as it is much finer and needs to be more accurately flattened to get the best out of the machine.
Chris Knight
14 Jan 2004
SE London - NW Kent
Nick,
Jason and Alf have shown the sort of thing I meant, I envisaged clamping one in a Tormek tool jig to use it. I have a gouge jig that I think would hold it securely at right angles.
Martin Brown
22 Apr 2004
BriMarc Airport
It would be my first purchase. Essential to ensure easier grinding.
Please PM for a more technical answer.
Martin
Scott
18 Oct 2004
I agree! As Chris says it can cause grooves if you're not careful but they don't cause a problem really
nicksmith
6 Dec 2005
South Yorkshire
Thanks everybody,
I wonder if my wife will object if I'm the one that get's the diamonds this Christmas!
Nick
