• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Withdrawn Imperial size T nuts
alan895
8 Dec 2012
Hampshire
A bit of a long shot but does anyone have any imperial size T nuts in their collection going spare? I'm looking specifically for a maximum of 3 (2 required, 1 as a contingency) that are suitable for a 3/8" diameter UNC 16TPI threaded rod.
I have attempted to tap an M10 size which does work but the fitting is a little loose. If all else fails I can tap the bare wood but it would be nice to obtain the hardware, I've looked around the usual places but cannot seem to locate a UK seller for them.
I wasn't prepared to pay just over £20 just for 5 from the States but I would be willing to pay a small cost plus postage to anyone who's willing to help.
TIA
TIA
Does it have to be a T-nut? Could you cast in an ordinary nut?
Brian
Since 3/8" is about 9.5mm, which is smaller than 10mm, that will indeed be the case.
How deeply does the 3/8" rod need to go into the nut? If only the depth of the nut, you could shave down the end of the 3/8" rod and use a die to put an M8 thread on it.
Another option is to use an M8 Unistrut nut retapped to 3/8". Form a pocket in the underside of the wood to accommodate it.
This any good from eBay
Click on pic and shows the thread size
Thanks to everyone for their input, I'm updating the status as a friend has kindly offered to machine a threaded mounting block for me.
