LFS19
I was wondering how square two pieces of wood need to be for edge gluing?
I've been practicing my joints and using the plane, and in another thread I wrote, it was said that often the board doesn't always have to be absolutely, perfectly square to work.
This was certainly the case for recent applications - I made a simple box with boards that weren't bang on square but very close to, and when everything was glued up you certainly couldn't tell.
Of course, it depends on what you're using it for.
As someone said in the thread, some things do need to be bang on and if they aren't, you're out of luck when you come to assemble.
I was wondering, then, where edge gluing falls on that spectrum.
Do two pieces of wood have to be absolutely perfect to edge glue them together?
I've seen a couple of things online regarding the wood compressing as it glues, and actually sealing the tiny gaps if there are any..
Thanks allot.
Thanks allot.
