How Do You?
devonwoody
11 Apr 2004
Paignton Devon
I got he Perform lightweight Door Set router cutter set this morning. There are no user instructions. At first I thought perhaps I undo the nut at the top of the 3 cutter set, but it now appears I adjust the cutters in the table.
Does this mean that a cutter duplicates its cut when using.
any working instructions appreciated.
DaveL
19 Oct 2002
Sudbury, Suffolk
Devon,
Have you got a Trend 2003 catalogue? The picture you need is on page 88. You can download a pdf of the page here it is 180K so can be a bit slow if the string is dry :wink:
I have of those sets, you will need to machine up a bit more timber than you need for the frame as you need a test pice or two to get the height of the cutter correct. :)
devonwoody
11 Apr 2004
Paignton Devon
Yes Charley looks useful.
My perform set doesn't even inform me what speed to run the cutters at then alone how to use or setup.
