How can I turn wood-black
Lightweeder
11 Feb 2009
Northumberland
I need to turn small black spindles, about 1.5" x 10". Blackwood is lovely, if difficult to turn and a bit expensive. I tried the wire wool and vinegar thing, but after a week of soaking together, nothing happened. Ordinary wood stains are another alternative, but not everything seems to take and I get dark grey. In the past, I stained stuff with Chestnut spirit stains, but they do come off on sweaty hands and need to have a finish of some sort. Can anyone suggest an easy way to turn black wood - or wood black :? please?
quite a number of my wood turning efforts end up as fire wood.......that tends to get the wood fairly black !!
The vinegar / steel treatment only works on wood with a high tannic content.
After all that I'm not sure
sue
depends what wood you are trying to stain, I have had good success on oak with india ink
I take it by your remark regarding stain coming off on hands that you do not want to apply any sort of sealing finish.
I take it we are talking something like chess pieces etc. If so I would have suggested using Chestnut ebonising lacquer, but the no sealer requirement rather precludes that.
nev":1pixqbtu said:
chestnut ebonising lacquer?
Thanks, but for spindles 10" x 0.5", (sorry, 1.5" mentioned earlier was an error) Chestnut ebonising spray is effective, but expensive. I could save them up and spray a batch, I suppose. I have it in stock and have used it, but it's not the answer in this case. I need a quick (not necessarily cheap) way to turn spindles black. Spraying something this size is not ideal.
I use black gouache. Its water based so putting a coat of lacquer over it doesn't lift it as it does with just about any other colouring I've tried. It has a very slight graininess which looks just like ebony when its lacquered. It covers brilliantly too.
black shellac? used for ebonising, break-up an old 78 record, soak in meths, make it as thick or thin as you like and 'cheap as chips'. chris
Gus 3049 - thanks. Interesting, but I'd prefer not to apply a finishing lacquer. Probably just my technique, but I always manage to end up with a 'gloopy' look.
Soulboy - I'll certainly give that a go.
Many thanks for all the advice.
This is the finish I get. I use acid catalyst lacquer thinned to about 60%
I've been experimenting with the iron wool and vinegar method (leaving them together in a jam jar for three weeks first) but its a petrolium black/dark blue, nice colour but not black.
i tried this too, but my wire wool dissolved :shock:
