transatlantic
Boom!
I like to make small boxes like the one shown in Figure A. Note, the finial is inserted afterwards, so can be ignored for this discussion.
But the the problem I always have, and haven't found a good solution for, is holding the lid so I can do a continuous cut and finish of one entire surface, i.e I want to finish the flat part as one cut, and also the hemispherical top as one cut. As shown in Figure E
What I currently do is form the lid from a spindle blank held in the chuck. I have the base of the lid on the end of the spindle so I can size it up to the opening of the box. I then sand and finish the flat part and a little of the curve. Figure C. This is then parted off.
I then put the parted off piece into a jam chuck and finish the rest of the curve. Figure D. The problem is that the part of the curve being held in the jam chuck now can't be finished as a continuous curve, and I inevitably get a discontinuation at that point. Not to mention the finish looks slightly different as it's been sanded in two different stages.
Just wondering if anyone knows of a better way to do this?
I have experimented with adding either a spigot or mortise as in Figure F which work, but they serve no purpose in the final piece. I would rather a clean flat bottom to the lid that I can decorate with texturing.
