shedhead
Hi
After the bad weather I went into my shed to turn. When I turned the lathe on the motor sounded as if it was labouring. I tried to increase speed but this was not possible. The higher I went in speed the slower the lathe turned. At first I thought it might still be cold/frozen, but I kept it running on the lowest speed to see if it would heat up. It just packed in and noe the motor just makes a noise with no movement.
I have the Jet 1442.
Do I need new bearings / belt. And how hard is nit to fix, remember I am thick at technical things.
Dermot.
Dermot.
