Jorden
I recently bought a second hand scrollsaw, well most of one, apparently a Delta 40-570 although there doesn't seem to be a delta model number anywhere on it.
I had to sort out the switch which didn't work, a quick blast of air sorted that and put a new power lead on it. The machine now runs I found a copy of the manual on the interweb, but it was in French which didn't help a lot, but it did show me where oil should go.
To get this machine working I need something to hold a blade in place. I've removed the head from the top arm to photograph what I have:
I don't know what the silver springy bit is, it appears to be bent, or if the scoring on the front of the head is normal, nor can I find anything to attach a blade with - the buttom blade clamp seems to have a part missing too, just the black forked piece is there, same as the top.
Other bits I'm missing are a hold down foot, I have the vertical bar it attaches to, the disc that sits in the iron plate to support the work, and a blow tube.
If anybody has any idea how I can fix this I'd really appreciate it.
Dennis
Dennis
