Handwork Pricing
Quite a few wood types new to me too! Lovely job though.
There's obviously many hours of work in that, I've personally not got the patience for marquetry.
Regards Rodders
Looks good, I'm not sure how the hair detail and fading colour areas can be done in wood though.
To the best of my limited marquetry knowledge:
The fading colours will be a combination of two things. If you check the sixth picture on the auction you can see examples of both.
- In the case of the more subtle variations, for ex. on the neck of the chap on the right with the grey beard (I'm sure he has a name), then it's a case of carefully selecting your veneers, so figure in the veneer is used to create an effect in the image.
- In the case of the darker, shaded areas, such as the cheek of the guy in the centre (let's call him Steve), you can dip the veneer quickly in heated fine sand to selectively scorch parts of it. Obviously any source of high heat will scorch, but the sand makes it easier to hit particular parts of the veneer. (I think he's gone a bit over the top on the cheek there, though!)
The hair detail - and other areas there's lines - can be done a couple of ways. One option is pyrography, but what it looks like here to me is that they've cut a line - perhaps with a scrollsaw - and they're using a glue that cures dark, perhaps with dye in it to darken it specifically. Maybe some kind of dark packing mixed in with the glue to avoid a sunken meniscus? I definitely reckon it's the glue, though - you can see the same fine, dark lines around the outside of most of the different colour areas as well, e.g. on the folds of the cloak of the chap on the left (... Frank?).
(Curiously the plaque in the last photo suggests the work is by a chap in Tehran, which I'm pretty sure isn't the same place as Manchester - so it might not be a case of the original craftsman valuing his work so highly after all...)
I'm not entirely surprised if $41 US was the 'winning' bid.
If that's true I doubt it would cover the costs of the materials. . . . . now where have I experienced that sort of thing before? Ah, yes. It's called craftworking!
It's all down to what folk perceive as value and worth. In the meantime a new Brit artist has sold an old empty squashed can of Dulux for £250,000. She had inadvertently stood on the tin of paint that happened to be in the studio.
This is an excellent example of boulle marquetry that has been produced using a chevalet, the detail of the hair is a result of using (usualy) a no2 blade the darkeness of the lines is from the hide glue thats been used.
The various layers of veneeer are placed in ascending layers and sandwiched into a packe which has the image on the outside. used to be done with a pricking method and is now done with a printed version and then sawn out by hand on the chevalet. you can see examples here: https://www.youtube.com/watch?v=2DCN2XHDx0g
