one is a cross cut and the other a rip cut. You could double up the rip as a biggish dovetail saw but it's not ideal IMO.
Im still confused.... I understand the concept of Ripping and cross cutting.. (in regards to the direction of the cut in relation to the grain) however i don't really understand the difference between the Vertas Rip Saw and the Vertas Cross Cut saw..
i'd suggest sharpening kit should be very near the top of your list as dull chisels and planes are as much use as a power tool without electricity.
I Agree. Any recommendation on sharpening? Oil, Water? Diamond? Paul Sellers says he likes diamond. where is best place to get me a some diamonds?
Another vote for the Veritas saws.
I agree! Iv just spoken to Axminister(They have a live chat on their site now! i feel i can pester them more then i would if i had to ring up, and its more covert while tool shopping at work! :twisted:
t is very easy to make winding sticks. If your budget is limited you shouldn't use any of it on stuff you can make yourself with minimal effort. If there is a scrap yeard nearby you may find some usable pieces of square tubing or you could just plane a pair of wooden sticks.
Paul Sellers has 2 videos on it. will check them out and make some
For a rip saw I prefere an old style 26 or 28 inch handsaw with rather coarse teeth. Mine is an early 20th century 26 inch Disston number 12 purchased for 5 euros. Any old handsaw from any of the old time high end makers is by far the best ripsaw money can buy and they don't cost much either. If you don't think you will be able to sharpen it then such a saw is totally useless....... it all depends on what you think you are able to learn.
Any recommendations on any "Old Time High End Makers" i can pop into my Ebay search? What recommended makers if i want to buy new?
For tennon saw I prefere an old style 14 inch backsaw. I have two one filed rip and the other crosscut. Must people use 12 inch backsaws but I find it easier to saw straight and controlled with a slightly longer saw. That may have something to do with my very long arms.
Both mine are 1970-80-ies resharpenable Sandvik saws with home made handles. Purchased secondhand for a few euros apiece. They became a lot easier to steer with handles shaped to fit my hands instead of the chunky plastic handles they came with.
Sounds Good, however, I kinda want to hit the ground running, and although re-sharpening is something i want to be possible on my saws, i don't want to have to sharpen them before i can use them(Future saws i will buy to sharpen but my first 1-2 i want sharp from outset.) this is why im thinking of sticking with Veritas for my tenon saws.. as i asked before whats different about RIp and Crosscut?
For a router plane I have an old Stanley. One of my friends bought a new Veritas. I have tested his and in my oppinion it is a good deal better than mine. If you can find an old Stanley dirt cheap like I did just buy it because it will be good enough but if you need to spend some serious money I think a new veritas would give more value for the money.
Any recommendation of the Stanley model number(s)?
If there is one piece of advice I can offer it is this, Don't buy tools for the sake of it only buy when you need when you need it.
I agree, However i do need to "look into the future" a little bit. i have collected together about £250 to kit out my first set of hand tools, if i don't buy them all in now then the money will dwindle away.. lol
I really don't see the need for a low angle plane (unless its a block plane, an I don't use the 2 I've got), I am a real advocate for the No4 can do anything if correctly set, if you happen on something it cant plane then a card scraper if your friend.
I am the same, iv gone through all of Paul Sellers videos and he turns to his #4 every time(nearly).. Iv got myself a traditional(vintage'ish) #4 off ebay, need to check the sole for flatness and give the blade a good sharpen then it should be fine!
(Sharpening fits into my question above! any recommendation on sharpening?)
Big saws are only really needed if you are prepping your own stock, if this is the case then I would also recommend a jack plane (wooden)
Umm... I want to build the Paul Sellers Bench, so i will be kind of preping stock... Jack plane is on my list, just want to get my Saws purchased and then see how much iv got left for more planes!
This will enable you to build boxes, anything else you will find out in time that you need or could do with.
Sweet!
Unless you buy the disposable type of saws, the issue of sharpening is going to come up regardless
whether you buy new or used.
I'd lean towards learning to do it by yourself, although they can be sent out to people who do this for a fee.
I defo want to attempt to learn to do it myself...
I think my saw list is going to be as follows:
new Vertas for Dovetails,Tenons(Rip or Crosscut?!)
New Gents saw(Because they look cool and they arn't that expensive for a nice High # TPI)
Ebay find Big panel saw(for long ripping?)
I will also need a recommendation on Saw Files for resharpening.
Thanks Guys! Apologies if this post is really long! im picking it up quite quickly just need that final bit of guidance!
Tom!
