Half lap joints
GrahamIreland
4 Jun 2015
Nottingham
Hi doing half lap joints on table saw and whilst this is fine for homemade stuff, there's a bit of play on the table saw.
Could anyone recommend how to get a more stable and reliable cut using this technique on the table saw.
Thanjs
MikeG.
24 Aug 2008
Essex/ Suffolk border
A wonky saw is a wonky saw.
The obvious compromise is to use the table saw to hog out the waste, but do the edges of the joint (the shoulders) with knife and chisel in the traditional way. If I am doing lots of the same sort of joint I'll do precisely that but using my radial arm saw rather than a table saw. Cut the marking-out lines with a knife, then start say a kerf inside the lines and do repeat cuts to remove the waste, then chisel back to the knife lines.
That would work
29 Dec 2018
Dartford
Either do the above or make a more accurate crosscutting sledge (there are one or two vids on youknowwhere).
Trainee neophyte
12 Apr 2019
Greece
I think your "mitre gauge" may be the culprit. Try a sled, as Thatwouldwork suggests.
pulleyt
24 May 2014
Nottingham
I've been very pleased with the results using a Flat Tooth blade with a 4mm kerf from Cutting Solutions in conjunction with a cross-cut sled on the half lap joints I've completed recently.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Sort the saw out. a tool that you cannot trust to cut repeatably is useless. Put in the work to sort it out and it will reward you in spades
GrahamIreland
4 Jun 2015
Nottingham
Yes, I'd like to get it sorted. Having done a project now with multiple half laps I'm getting into the swing of it.
I think the mitre gauge is just a bit of a loose fit.
May try making a sled.
