Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 1
Greetings folks,
Having had a certain amount of enjoyment building the first guitar, before I had finished it I made a start on the second one. This was to be slightly different, and upping the 'Eeeeek' factor a little too with regards to "How on earth am I going to do that?". The inspiration behind the guitar was from a collection of posts on MIMF (American luthiery forum) by a chap making semi-hollowbody guitars. The second inspiration was the fortuitous accumulation of reclaimed university workshop bench tops (engineering, not woodworking), the timber being labelled as afromosia. I figured that if I make a hash of the project, I will have spent very little as the afromosia cost a couple of car journeys worth of diesel.
Right then, on with the project.
The idea was to use the same external shape of my previous 'model', and hollow out the inside. Not in the manner of an archtop (carved or laminated), rather taking two slabs and routing away most of the inside then gluing together. The pictures explain better than my words, but it is a sort of clam-shell approach. Electrics are to be provided by 3 single coils (again a set from Bareknuckle), hardware Gotoh 510 series, a glued in neck (noting angle issues this time) of indian rosewood (sliced off from a billet intended to produce one neck, I decided to use a scarfed join at the headstock and this way will get 3 necks instead of 1) with a locally sourced laburnum fingerboard of 22 frets.
Here are a couple of samples of the wood as I received it. The thicker slab shows reasonably good QS, but also evidence of bench vice and years of engineering detritus. The cut away corners on the thick slab are there because I couldnt work out a way to remove the screws that were protruding from underneath. It was only after taking a couple of layers of grime away from the top did I notice the doweling used to conceal the screw holes from above. Sneaky.
I made very good use of a scrub plane to clear most of the muck, following up with swipes from a 5 1/2 or 6. At this point I would like to say what an absolute pineapple this afromosia is to plane - you may get an idea from some of the photos - from the interlocked grain to the (I think) silica deposits that blunt the blade from across the garage. I am lucky enough to have a second hand Performax drum sander from eBay a few years back, and I made very good use of it to thickness and remove planing tearout.
A view of the rear, showing off some nice figuring in the wood. beeswing? Now, here is an example of my first mistake, a variation on a theme of "measure twice, cut once". Somehow, despite double checking and labelling each side of the timber blank for orientation, I went on and routed out the internal cavities on the wrong side (for both the original front and back). There were two options - 1) build guitar as if it were left-handed (but I didnt like the aesthetics of the horns that way around) or 2) build it back-to-front. The second option was the better, I felt. The only reason I had originally gone for the other way around was visual.
The front, showing the f-holes (mostly of a visual nature and not really playing the same role as those found on acoustic instruments, i.e. sound distribution) and a faint outline of internal routing and pickup placement. By now, it has obviously been glued back and front together, and the three-piece front is not as nice to look at as the bookmatched rear. I was parrticularly pleased that I managed to resaw, with very little wastage, this timber. Thank you SIP and Tuffsaws.
With a garish purple rough overlay of where the internal cavities lay, with a central block hollowed out from the rear (shaded pinkish red) that will house the pickups mounted directly on the front. I am making this overly difficult, I feel.
Moving onto the neck, heres the rosewood blank marked out and ready to be sawn.
Headstock scarf joint cut and tidied up with a handplane (I think I used a Clifton 6 here, despite the size difference, the Clifton cut nicely on this timber)
Once glued up, I checked the neck (with the stacked heel too) with my scale-length rule. And here is my second mistake. The end of the neck should sit at about where the 25-26th fret would be. Not the 20th. Damn you, measure twice rule!
Please see following post for resolution to this problem
