jpt":f65ldcp7 said:
.......Some turners, chas is I think one of them if not I apologise although I am not having a go, only sand to about 240 on English woods saying anything finer doesnt make a difference. I disagree with this and think the difference is obvious.
john
Better put that into context, I consider any grit abrasive as just another tool, albeit one with a multi faceted cutting edge and should be used like any other so that there are no tool marks visible when the piece is finished.
Regarding minimum grit and wood types, as long as the scratches you leave on the surface are no greater than the wood structure, and lined up in the direction of the grain, and are not visible to the eye then why go ever lower to polish the high points if the surface coating you are applying is going to provide the gloss.
Now down to the 240 minimum grit statements, I think you will find that the majority of times I make this reference it is to items that are to be sealed (hardened surface) and then buffed through the grades which in effect takes the surface down well below the 600-800 grit level with no detectable scratches, therefore no point in sanding these pieces below 240-320 prior to sealing.
There is also a school of thought that with some surface finishes that too highly a polished base surface reduces the bonding capabilities of the subsequent finish.
I'm of the opinion that if you can't detect any scratches on a finished item regardless as which grit you stopped at then you have sanded fine enough.
Always remember the adage, "Sand with the grain" which with turning subjects may mean doing as much if not more with the lathe stationary.
