Dusty Ears
New member
Firstly hello everyone!
I've been reading through the forum for a while now trying to pick up whatever I can to help in my understanding of turning. I think the main thing if learnt is that you are always learning!
I was grateful to get a lathe from the wife and kids for my birthday, as it has been something I have wanted to do for quite some time. However I have quickly noticed the limitations of the lathe. e.g. the tool rest is not very easy to adjust, changing speed is not bad but could be easier and it doesn't feel too solid.
Wood Lathe 1000mm Wood Turning Mini Lathe
I plan to grind down the end of the tool rest to enable it to be more safely secured. I have already had to shorten the handle (to tighten in position) as it was impossible to tighten enough when the tool rest is nearer the head-stock.
I currently have this tool set Axminster Woodturning Tool Set which I think will do me fine while I learn to both turn and sharpen.
On sharpening.
I don't (and won't for some time) have the money to spare on a bench grinder and the appropriate wheels, but I do have a small bench sander and various drill mounted stones. The stones seem to have the advantage of giving a clear view of what I am attempting to do, but I appreciate that this may not be the best way forward (?).
Having read how delicate a subject sharpening seems to be hope I haven't thrown any grenades into the room!
From what I have read so far I think my tools are not sharp enough, although there is also the added problem of lack of experience. I do feel that if I can at least have sharp tools it will help with the learning process.
Apologies for the long and probably painful first post (I can almost hear people wincing when they see the lathe) but I feel if anyone can give some advice and a way forward it's the members on this forum.
Anyway, thanks for reading.
Michael
On sharpening.
Michael
