Evening all, hope your all enjoying the holidays.
Now down to business, I moved into my new house around July this year and now it's all renovated I'd like to finally make the garage into my workshop.
It's roughly 5 x 3m with the garage door at one end and a door leading to the laundry at the other. The wall to the right of the pictures is the external wall of the house. Hopefully the sketchup pictures will explain thing a little easier.
So, it's pretty cold in there at the moment, mostly due to a very poorly fitted up and over GRP garage door. I will replace this and draught-proof / insulate as much as possible.
The other cause for the cold (I think?) is the uninsulated roof. As shown in the pictures I plan to plasterboard and insulated between the joists with 100mm Rockwool.
Then I'd like to batten out the external wall, 25mm ridged foam insulation between the battens (flush to the face of the battens) and clad with 18mm ply. Then surface mount the electrics to this wall. This is to give me a wall I can easily hang tools / shelves. I've seen the youtuber "gosforth handyman" do this, linked below if I can.
That's the plan anyway, does anyone have any advice or see any problems I might have? I am wondering if I'll get condensation behind the foam insulation? Also do I need the put DPC behind the battens?
Any help would be appreciated.
![GARAGE_1.png GARAGE_1.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80326-GARAGE-1.png)
![GARAGE_2.png GARAGE_2.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80327-GARAGE-2.png)
![GARAGE_3.png GARAGE_3.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80328-GARAGE-3.png)
![GARAGE_4.png GARAGE_4.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80329-GARAGE-4.png)
![GARAGE_5.png GARAGE_5.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80330-GARAGE-5.png)
![GARAGE_6.png GARAGE_6.png](https://cdn.imagearchive.com/ukworkshop/data/attach/80/80331-GARAGE-6.png)
