Furniture lifters?
peter-harrison
25 Jan 2018
Cambridge
Hi, I recently bought a couple of these from eBay. The idea is great but these particular ones are a disappointment as they slip under moderate weight. Has anyone got a recommendation for where to get good ones?
If I need to temporarily lift a piece of heavy furniture and I'm on my own for say installing a piece of packing for levelling I use these type of feet. They're meant for permanent fixing but I just insert some wood so the base of the cabinet is within the 50mm range of the leg and then wind it up.
Airbags like Winbag or similar copies.
They wont lift it high but are remarkably strong, you can lift it then wedge a plank under and lift it some more.
Ollie
I use a crow bar or pick axe and then scaffold tube if I want to roll it!
Cheers James
