Fridge, freezer or chiller
RogerS
20 Feb 2004
In the eternally wet North
LOML needs to store some things at around 1 deg C. Our old fridge won't get down to that level. I see that some modern fridges have 0 deg C compartments for meat but (a) the amount of storage wouldn't be enough and (b) don't really want to shell out loads of money.
So does anyone know if freezers can be run at this temperature level or do they get unhappy?
Or am I way off the mark and that this is something that only a dedicated unit like a meat chiller will provide.
Many thanks
Roger
We have a newish fridge freezer and the bottom section of the fridge get's down to around 1deg or so. If I put meat in the bottom, it part-freezes (but not completely) so I guess it's around the temp your after - Rob
Thanks for that, Rob. Thing is though she needs the whole volume to be at that temperature.
We have a Hotpoint Aquarius fridge and you can set the whole compartment down to 1 degree. Bought years ago - but I would have thought the current one would do the same.
HIH
Dibs
Our whole fridge goes down to either +2 or -2 which may be close enough to what you need. It is a no name, so I doubt it was expensive (we bought the house with it in). I havent put a thermometer inside it, but the digital readout offers the option down to this level- i would think that you could adjust the temperature lower by putting an ice pack or two in- would take a long time to melt because it is so well insulated. I know that when we first moved in I put in meat to defrost and 24 hours later it is still pretty solid.
We have two larder fridges a Siemens and a Miele - they both freeze things if accidentally set to the wrong setting!!
Rod
chuck a thermostat in the freezer, but have it switch off instead of on when it gets down to the temp you want.
Used chest freezers should be easy to get cheap
EDIT ... dont be putting mains wiring inside though. ! find someone who can do a 12v system, if you cant do it yourself
I have a freezer BEKO it freezes to -1 and the chiller go to +1 good freezer perfict for what you need
Hope it was a help to you Rob :roll:
furniturefanatic
