D Hart
Hi all,
Hope I'm posting in the right section...
Have just bought an old fobco star, which seems generally to be in very good used condition, if rather grubby. Certainly no play in the spindle/quill and the table is in good nick, with virtually no damage. I'm tempted, however, to do a basic strip down and rebuild, just so I know that all is as it should be in the workings. I have the dismantling guide from lathes.co.uk, which is very comprehensive, but I do have some questions to put to you all before I embark on this.
The main question I guess, is how achievable is this for someone with limited experience refurbing machine tools, as well as a relatively limited range of tools at my disposal. The guide says the engineering and construction of the drill is quite straightforward, but I still have some reservations, so feel free to provide encouragement at this point! Does this even need doing, given that the machine seems to have been fairly well maintained and is in good working order?
Most of my worries boil down to reassembly, where the guide says to end-load the bearings, but gives no indication of how much end loading is required. So any guidance on this would be much appreciated, as well as advice on the best way to achieve this - I think some of you have used long clamps to do this? Or should i just be leaning on a length of steel tubing? I'm particularly concerned about the 'single smart tap with a two pound lump of brass' required to seat the bearings, as this seems very specific but at the same time quite vague. Certainly, I don't have a two pound lump of brass, and I worry that my idea of a smart tap might differ from that in the guide, so I'd be very grateful for any advice on this also.
Finally, some advice on the best lubricants to use would be very useful, as well as some idea of how often the machine requires lubrication.
I'm sure once I get under way with this, there will be a host of other queries but I think the above is sufficient for now and any advice/guidance would be most gratefully received...
Thanks in advance ,
Diccon
Thanks in advance ,
Diccon
