Fobco Star Bench Drill - Head Assembly Clamp
Macca_UK
11 Nov 2021
Barnsley
Hi all,
I've just landed upon a Fobco Star and have a question about the head assembly clamp, or perhaps the lack of it...
I have a clamping lever that is part of the main head assembly casing, but I've seen pictures of other Fobo Stars and they have a separate split clamp that sits underneath the main head assembly,
I've also seen plenty of pictures like mine, where this clamp is missing.
I'm assuming the purpose of the second split clamp is to take the weight of the head assembly when you loosen the clamp on the head to rotate it (and to stop it falling).
So, am I actually missing a clamp or were some models just produced without one (it would seem a strange thing to remove it it originally had one fitted).
Macca
flh801978
21 Dec 2008
Sheffield uk
It’s missing
Sometimes though people put it under the table but you haven’t one there too
It’s only really a chunk of steel bar with a 60mm( As I Remember ) hole through with a locking screw in the side
Ian
dickm
25 Oct 2004
North of Aberdeen
Mine doesn't have one either. But if you really want something to stop head/table slipping, a Jubilee clip would probably serve.
Macca_UK
11 Nov 2021
Barnsley
Thanks for the replies,
I'm not so concerned about it slipping, it's slightly rusted/stuck on at the moment and it took a few taps just to get it straight to the base.
I'll file it under the things to ignore for the moment.
One more question whilst I've got your attention, how is the small rotating depth gauge supposed to work?
You can zero it, but after a few plunges it moves off from the set zero point - Is it just a matter of messing with the bolt tightness?
Macca
flh801978
21 Dec 2008
Sheffield uk
The bolt should be tight as you can get it…the friction is supplied by a spring washer under the cap…maybe remove the bolt and clean out old grease that will be there carefully replace the spring washer and place the cap on and tighten the bolt up..
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
I only use the depth gauge to set the depth stop rather than on repeat holes. Touch off on the piece and set to zero mm, remove workpiece and lower to correct depth, set depth stop for repeat holes.
Macca_UK
11 Nov 2021
Barnsley
Thanks for that - I'll take a look at the weekend
