dennyom
Hi! I just got a hold of a bunch of 100 year old hardwood flooring salvaged from a tear down. All of it is in good shape on the top side but some of it is roughed up on the edges and and some have split tongues so will need to be cleaned up. Most of it is oak with some of what appears to be maple mixed in. I would like to use it for a new counter top in my work shop. Has any of you done this and how have you fastened the flooring down? I was thinking of 3/4 ply or MDF under lay. Can the flooring be glued to this? Can the flooring be edge glued together and them attached along one long edge to allow for movement of the wood. The counter will be 16' long and about 24" to 28" deep. This will not be a workbench but I may put a grinder, mini lathe, and a drill press on top of it.
