Flattening Burr Verneers
srs
10 Oct 2005
Ok this is not for the chopping block, I've just purchased some European burr walnut (0.6mm if that matters) verneer leaves which I have been told will need flattening prior to use is this just a matter of sticking it between 2 boards for a day or 2 or as with many things in life is there more to it than that?
Simon
Chris Knight
14 Jan 2004
SE London - NW Kent
Burr veneers can be frustratingly difficult to flatten. I have found the following to work fairly well.
Start by wetting them fairly well (well enough that they don't crack when flattened but note wetter), place between several sheets of newspaper and then sandwich that with MDF or chipboard which in turn can be weighted down or pressed if you have a press. Leave a few hours then change the newspaper and leave again weighted down for several more hours.
Remove the veneer and leave it on a flat surface to dry properly. If it stays flat, great, other wise you will need to make up a flattening mixture and repeat.
A formula for a flattening solution is
* Four parts water;
* Two parts glycerine;
* One part meths and
* Two parts PVA.
Glycerine is expensive if you buy it a chemists and at a pinch you can use just a glue size PVA (thinned with water) but when using this gunk you need to cover the veneer with thin plastic to stop newsprint sticking. The thin decorators' dust sheet stuff works OK.
If you apply the veneer before it's dry, it will crack as it dries and that can really spoil your day, so don't be tempted to do this.
If this doesn't take your fancy try some of the ideas here
http://www.joewoodworker.com/veneering/flattening.htm
