gaci
Hi all, does anyone have the knowledge they can pass over of how to add a separate emergency stop button on my bench linked into the on/off switch that is mounted to the motor? Diagram would be great. Cheers
gaci":2170shsq said:Found this , i think it looks like you describe
We are talking at cross purposes. The Emergency Stop Button is a simple switch. With the button sticking out (it's normal position) it is ON and will stay that way till the end of time unless you push it. It with then latch in the OFF position until the button is twisted to reset it. Meanwhile the NVR will have dropped out because of the interrupted supply.gaci":1qfa4n9l said:the wiring diagram posted is where all on and off switches work. Its pointless fitting an emergency stop button when you still have to go around the back to turn it on or reach over what your turning. Good idea Bill and yes easy to do, but require it to be like the diagram posted.
Grant
