Finish for oak door casing
orval
31 Aug 2011
Bolsterstone
Hi,
I'm making an oak door casing at the moment. This is my first project like this and I know naff all about finishing. I've been Googling about but I can't find many resources for this.
As far as I can work out, the choices are: wax, oil, hard waxoil, polyurethane varnish, some-other-kind-of-varnish.
I'm thinking hard waxoil, perhaps Blanchon (natural -- I'm not after staining it.)
I'll also be doing some skirting boards soon, so preferably I want the same finish on both.
Any advice?
Thanks,
Orval
RogerM
4 Mar 2006
Devon
Osmo PolyX oil would be my first choice. Widely used on floors so pretty bulletproof, and if you're using for skirting it will need to be hard wearing because of scuffs from vacuum cleaners, brooms, mops etc.
woodpig
17 Sep 2011
Dorset
Does it darken the wood like other oils? I have some Oak veneered doors that need finishing but we don't want them much darker than they are untreated.
RogerM
4 Mar 2006
Devon
Yes, it does a bit. It's always desperately difficult to get a clear uncoloured finish. Why not contact Terry at Chestnut oils? If anyone knows he will. I saw him demo a sanding sealer finish followed by wax at the Yandles spring show and it didn't seem to colour the wood. I'll be interested to hear the answer myself!
orval
31 Aug 2011
Bolsterstone
Putting the stock through the planer I notice the grain is quite open.
Would you recommend I use grain filler? If so, what brand would you recommend?
Krome10
17 May 2012
South West Wales
I'm in a similar boat to the OP, and want a finish for my oak doors which will not darken or change the colour.
I've googled Chestnut Oils but it just takes me to an Internal Error message. Do you know if Terry/Chestnut oils are still about and if so how I might get in contact with him?
Tomyjoiner
25 Jan 2012
Cumbria
I usually do 2 coats of sanding sealer then a quick denib with oooo wire wool then put the wax on with 0000 wire wool aswell then just buff up. i find its the closest to a natural colour on oak.
Tomyjoiner
25 Jan 2012
Cumbria
Its 0000 grade wire wool very fine, iv done quite a few stairs this way. The wire
Wool has no effect on the oak as it has been sealed with sanding sealer.
Tomyjoiner
25 Jan 2012
Cumbria
Well if you try some 0000 on scrap piece you will see it doesnt mark it, an
Like i said in the post you are not directly on the oak as the sanding sealer
Has put a clear coat on it.
