I used a similar process for my oak.
Liberon or Bulldog Steel wool in Cleaning Vinegar, 6%, strongest I could find locally, Pickling Vinegar is supposed to be up to 10%. I held it under the vinegar with old steel spikes and agitated it every day for about a week until there was no more activity. Filtered it out through a few layers of cotton T-shirt and then coffee filters.
I also made a solution of hot water and Wine Tannin from Amazon. It is normally used to impart an Oaked flavour to home made wine. Disolved whatever it would take. Used it because I didn't know whether the Oak (salvaged church pews) had any sapwood in it.
I would wipe the Tannin solution on the Oak and let it dry, then do the same with the Iron Acetate solution (steel wool/vinegar solution).
First go around wasn't dark enough so I repeated both steps again. Interesting to note the Oak was more blue black after the Tannin than after the Iron Acetate applications.
I think I repeated the process 4 or 5 times.
Between applications there would be a dry blue black dust on the surface that I rubbed off followed by blasting with shop compressed air to clean out the pores.
Then I applied Tried and True Finish on it, a linseed oil wax mix, rubbing off all the excess after letting it soak a little. Repeated about 3 times over several days.
I like how the Oak even though black, still shows the grain and figure of the wood. Opinions may vary.
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
The wife is happy, so am I.
Pictures are of the Oak with the Tannin, with Iron Acetate and the oiled finish.
By adding Tannin to other woods that don't normally have any you can ebonize them too.
P.S. I'm not trying to hijack the thread.
