Thank you for the explanation. It must have been too early in the morning as I hadn't picked up on the plunge and hold, even though I'd watched the video.Neil":10kd3cyo said:My guess is that because they want it to work like a biscuit jointer (i.e. held against the work and then plunged with no sideways movement) they had to use an oscillation - imagine how hard it would be to design a mechanism which plunges the bit to full depth and then moves it sideways, all driven by a simple plunging motion by the user. Its a pretty impressive piece of engineering IMO.
Neil
Thanks for your reply. It certainly looks to be a very impressive piece of kit, which should find a niche market.waterhead37":3q2bf07t said:I can see that this tool will be a very versatile thing and a delight for working pros. Imagine being able to joint on site using loose tenons for example.
