blackteaonesugar
Hi, my Festool CTLSYS vac has developed this weird issue where when I'm using the power take-off for the Domino df500, the vacuum pulses rather than giving a constant pull.
It only does this on the power take off mode with the Domino machine. If I just turn it on via the switch, it runs constantly as normal and if I use any other tool from the take off such as my sander or biscuiter it runs constant. As soon as I go back to using the Domino tool, I get this rhythmic pulsing again.
I've just checked with a colleagues Domino machine and it does the exact same pulsing thing, also with a different power cord. Very strange.
I've cleaned the filter(was very clean anyway), changed to a new bag, checked the hose for blockages by sending a rod through it, ran the Domino off another wall socket, all totally fine.
Anyone had an issue like this?
I called Festool this morning and am waiting for a callback, but when I first called I thought the issue was the vacuum not the tool.
Then I thought it was the tool but having tried the same tool belonging to a colleague with the same symptoms, I'm at a bit of a loss now what's causing it.
Any ideas?
![Screenshot_20230704-093452.png Screenshot_20230704-093452.png](https://cdn.imagearchive.com/ukworkshop/data/attach/142/142951-Screenshot-20230704-093452.png)
Any ideas?
