paulrockliffe
I picked up a somethingorother chip extractor via eBay from a chap whose neighbours were kicking up a fuss about the noise, £50 and something like 2.5hp of suction. It has two 100mm inlets and I acquired 5m of flexible hosing for it.
Since I got it in the summer I've not had chance to do a lot with it, so it's either used with someone holding the end of the hose for me or just for vacuuming up the floor, which it does a great job of!
All of my kit takes standard vacuum cleaner hose, when I tried a step-down adaptor I discovered that the restriction is so severe that it stalls the airflow, the filter bag doesn't inflate and the airflow is lower than my original draper vacuum. So my intention was to make a 3 x vacuum hose manifold so I can collect from a few places at once. That hasn't happened yet.
Anyway, I've built a router table and need to add some extraction to that, I have a rough plan, but wondered where people go to buy ducting pipe etc? I've had a look around the internet, but not exactly sure if I'm looking in the best places. I've been looking at 100mm ventilation ducting, which isn't sold for this sort of thing, but is the right size. Struggling to find long pipe runs though, so there's probably a better place to look.
I'm also considering using some square pipe inside the router table as it'll fit better around my drawers etc and would allow me to drop the pipe out of the bottom. A little unusual, but I'd like to be able to have the option of keeping the table up against the wall while the extraction is hooked up if I can. I was thinking I'd drop the pipe out of the bottom and then run it to one side where an adaptor from square to round can be attached. Another advantage of the square stuff is that it should naturally make a better pick-up at the bottom of the router cabinet.
Any thoughts on the size of hose to run to the back of my fence? 100mm would be too un-wieldy I think.
So generally, I'm after advice on places to buy and whether the square ducting will be fine?
