Elu E4001 Dovetail Jig
A
Anonymous
Guest
My good friend Keith ;) is giving me a Elu E40001 dovetail jig which he never uses.
Im just interested to see if anyone uses one or has used one before to get a bit of knowledge before it arrives.
Im hoping to use my small Bosch 1/4 POF 500 A Router with it as my DW 625 EK is in my table.
Thanks everyone and thanks again Keith
Jase
DaveL
19 Oct 2002
Sudbury, Suffolk
Hi Jase,
I don't know what an Elu E40001 jig looks like, but I have a pof 500a that I use with my Trend jig, the old one. The jig uses a guide bush and I bought the Trend Uni base, this looks like a slice of swiss cheese it has holes in to allow it to fit on to lots of different routers, then the Trend guide bushes fit onto it. Works a treat and the little router copes OK for both 1/4" and 1/2" dovetails.
A
Anonymous
Guest
Hi Dave
Thanks very much. I have the uni base which i used on my Large DW 625 EK and have a load of bushes. Is there a smaller uni base ? or do you just use the standard large one?
I would have thought it was a bit big for the small Bosch, could be wrong just guessing.
This is the one i have, is this the one that fits on your Bosch dave?
http://www.powertoolsuk.co.uk/webcat/de ... SE&ID=1779
Thanks again
Jase
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Pretty sure there's only the one size of Unibase. I guess you could trim it once you have it screwed on and use a pattern / flush bit in another router.
Noel
DaveL
19 Oct 2002
Sudbury, Suffolk
Hi again,
Noel is right there is only one uni base. 8) I have not trimmed mine, having a bigger base make the router more stable, the only time I can think of needing to trim it is if your working in a tight corner. There is no need to trim on the Trend jig. :lol:
A
Anonymous
Guest
Thanks Dave
Which Trend jig do you have, i know you said the old one but which model ?
Jase
DaveL
19 Oct 2002
Sudbury, Suffolk
Jase,
Having just rummaged out a Trend catalogue, mine is a DJ300.
Having looked at the pictures in the catalogue :D do you have a fine height adjuster?
The pof 500 doesn't come with one, I bought the Trend one and had an adaptor made so I can use it on the Bosch. 8)
Its very useful for getting the joint just snug. :wink:
A
Anonymous
Guest
I have an adjuster but not on the Bosch, it's on my table. Will have to manage without :cry:
A question for everyone really, i want the jig just for doing dovetails in 12mm Birch ply which will be drawers. Will it be ok dovetailing Ply ??
Jase
DaveL
19 Oct 2002
Sudbury, Suffolk
Well I made draws for our Hi Fi cabinet, pine fronts the rest of te draw 3/8" ply. I did not post pictures of just the draws but look at this for a draw in the unit.
It works OK but you need good ply without voids in or it will go pear shaped. :roll:
