Steve Maskery":3vqxr2q2 said:Chems
First I tried to dril a 30mm hole with a hole saw. Fortunately I tried it in a piece of scrap. I'm glad I did as it was a disaster. Rough as a rough thing that's been roughened. But this method worked:
Drill a suitable hole in a block of wood
Drill 3 holes in your plate, two for screws and one big enough for the bearing on the roundover cutter.
SCrew the block to the plate and use the bearing to flush the ally hole to the wooden block.
Chems":2wfsj3ei said:I'll defiantly do this mod myself.
Henning":2wfsj3ei said:One thing i'm wondering though, is how do you think this will affect the plate in the long term when it comes to sagging?
Chems":3rgfvfzp said:definitely! I have a total brain block on that word!
change the mounting block for an L-shaped piece, so that the swing point was way off to the right instead of being just off the edge of the table.
