frugal
I am beginning to think that power tools hate me. Last night I went to thickness some wood and my Dewalt 733 thicknesser refused to start. It worked fine when I last used it, but last night I pushed the start button and nothing happened; it didn't trip the RCD; it didn't blow the main breaker as everything else seems want to do, it didn't hum or whir as though the motor was trying to turn and failing; there is no burning or electrical smells. Nothing.
I check the obvious things:
- The fuse looks good
- I pressed the little reset button on the top of the motor (doesn't seem to move very far at all), both with the plug out and in, and with the start button pressed or not.
- With the plug out I checked to see that the cutter block went around - it does.
- If I take off the extraction hood there was a fair few chippings, but nothing blocking anything.
- With the extraction hood off I can see the fan at the back, if I rotate this by hand it moves easily and the cutter block also rotates, so it does not look like anything has jammed.
- If I unscrew the switch on the front I can see that the wires are all plugged in.
I can not get at the rest of the motor without taking the whole thing to pieces. So it looks like my options are to find a Dewalt repair centre, or to hope that someone on this forum has had this problem in the past and has a cunning solution.
Any Ideas?
Any Ideas?
