paul24dual
Do you guys always where dust masks when woodworking and what other protection do you use?
Doesn't scroll saw produce fine dust?paul24dual":2daz5cu5 said:and you would always wear a mask even when just scroll sawing etc?
paul24dual":2n82vtvk said:and you would always wear a mask even when just scroll sawing etc?
This is not the type of filter that you require for wood dustspaul24dual":2wgrfedd said:How many times can you use these before replacing?
http://www.ebay.co.uk/itm/251415125471? ... 1423.l2649
It is? It's a P3 filter which is good enough for use with all woods and mdf according to that pdf.Vic Perrin":31cnsrpf said:This is not the type of filter that you require for wood dustspaul24dual":31cnsrpf said:How many times can you use these before replacing?
Have a look at this link
http://www.hse.gov.uk/pubns/wis14.pdf
carlb40":170ry8ko said:It is? It's a P3 filter which is good enough for use with all woods and mdf according to that pdf.Vic Perrin":170ry8ko said:This is not the type of filter that you require for wood dustspaul24dual":170ry8ko said:How many times can you use these before replacing?
