dust extractor
wallace
13 Feb 2011
county durham
I want to improve my dust extractor. At present I have a 1hp chip collector connected to a 55gallon barrel acting like a thein filter. My pipework is 100mm. I dont know whether to make a blower like mr pentz or try and improve the stuff I have. One idea I was toying with was to add another chip collector extractor. If I have two extractors do you get double the suck?
Mark
Hi Wallace,
2 machines should help (depending on where you place them in the set up or split you set up in 2).
A bigger motor on your existing unit could be expensive & give you no more suction but greater resistance (I looked into that recently).
I believe it's a combination of motor rating, fan dimensions, duct design & duct integrity that make for suction power.
I eventually replaced my ok machine with the twin motored, 2kw, Record DX4000 that I found on here & I am very happy with it - it's quiet & very powerfull ..although I'd have preferred the wall mounted bag collector type but you can't have everything.
I hope this helps
Steve
