chippy1970
Anyone got any good ideas for a dust extract port on my router table fence. Below is a picture you can just about see the clear 6mm lexan that I have fixed at 45 degrees on the rear of the fence. I need to drill through this and maybe fit some sort of waste plumbing fitting to the fence. The pipe that will connect to it is my Festool midi vac which fits well in a 35mm hole. Can anyone whos done such a thing point me in the right direction ie what plumbing fitting did you use??
EDIT Im thinking maybe this will work I have an idea that the internal size of this fitting is 34.5mm from what Ive read whilst Googling. This has a flange on it so I can drill a hole and just glue it in place. http://www.screwfix.com/prods/63577/Plu ... Pack-of-5#
![5393656302_c3830d5828_z.jpg](https://proxy.imagearchive.com/02c/02cc67cd96f2527468f795a12ffa53da.jpg)
