Quantcast
Dust collection port mismatch?
TheUnicorn
21 Feb 2020
Bristol
have seen similar, what i've not seen is the combination of two pipes as per the second build. that's a helpful technique
I use a rubber hose thing (some random plumbing bit I found) and a jubilee clip. the one tool I have struggled to do anything with is plane with an awkward oblong port, also very shallow which doesn't help. I don't use it much, i might try shaping a model of the port from wood, sanding to a funnel shape and moulding some pipe, realistically, I probably just put up with sawdust until I need to replace the machine.
pe2dave
2 Oct 2007
Peterborough, Cambs, UK
Bosche planer? Square dust outlet? Likewise. I think this is where we need someone with a 3D printer! Ideal task for that.
Re 'heating 32mm plumbing plastic'. Just tried it. Really struggled to get it over a 34mm inner. Not yet sure how much heat they
will take! Going to have a wonder round B&Q and see what other sizes are available.
Went round the tools with a ruler: Range is 22 (palm sander) to 100 (bandsaw),but around 40mm is common.
On some it would be helpful if I could 'shrink' the 40mm down a little!
TheUnicorn
21 Feb 2020
Bristol
I believe it is a bosch, I was given it and it gets little use, a problem I often have with it is the cut depth seems to move of its own accord (vibrations?), have you found similar?
TheUnicorn
21 Feb 2020
Bristol
I think the key is a slow gentle heat, if it starts to colour up or ooze in any way you,ve gone too far, I made a simple box with square edged plastic conduit, heating to allow folding of the sides (as you would sheet metal box) I found it would take ages to soften, and then was almost too soft all at once, I think I had my heat gun too close?. My concern, and why I've never used this technique, is the heat transfering into the plastic ports on the tool and damaging them, but I think the risk is minimal if care is taken.
also you mentioned wanting to shrink down some 40mm, I believe it does contract somewhat when cooling so that might snug up any gaps. Trial and error I think
Anthraquinone
4 Dec 2013
Mirfield
While the hard plastic idea seems to work have used silicon hose off cuts from a car parts supplier near me. There are many diameters that will fit one over the other if needed and of course will bend as required
pe2dave
2 Oct 2007
Are they sold in short lengths? Did you glue them please? Neat idea.
pe2dave
2 Oct 2007
Excellent idea for pipework, vac to machines - I can't see how he is connecting his 'plates' to individual machines without adaptors? There must be a pipe (even if short) from the machine to the plate?
Any ideas?
