AES
Gents, I'd appreciate any guidance you can offer on the following.
Having just been lucky enough to get hold of one of Steve Maskery's cyclones, plus having found a decently-sized metal dustbin cheap at the local DIY Emporium, I obviously need to couple it all up to my existing shop vac. It's a Karcher and apart from the horrendous noise it makes I'm very pleased with it 'cos "it sucks like a goodun". I tend to use it for fairly lengthy periods (30+ mins perhaps) and so my first question is:
1. When running am I correct in thinking that internal heat (within the vac) will be dissipated when I run the vac with the "blower hole" open? That's my present practice and this does NOT seem to materially affect the powerful suction - at the end of such session both the exhaust air and the outside of the motor head are definitely a bit hotter than just "warm", but in my judgement, nowhere near excessively so.
2. Because of the present high noise level, and as when the cyclone is connected I guess I'm likely to run it for even longer sessions than the above 30 mins at a time, I'd like to build a small enclosed cabinet with baffle to reduce noise - as per several examples seen on the internet. My question is, will such a cabinet be likely to reduce the life of the vac (it's already several years old) due to higher heat that, surely, must build up within the cabinet?
Any pointers gratefully received.
TIA
AES
TIA
AES
