Drawer Slides for Beginners
SteveF
16 Sep 2013
Maidstone
Last part of my build to be decided
I will be using wood runners for my cutlery canteen build
what is the easiest for an amateur?
bottom runners or grooved into drawer sides?
I have false drawer fronts if it makes a difference
Steve
Bottom runners would probably give you a few more options to correct and adjust if everything doesn't work out exactly as planned. It's still not a bodger's charter, but it's a little more accommodating than side runners.
thankyou both
was the last part of my drawing \ build
I have sunk over 100 hours into this project (could have halved that if had new timber to hand,so lesson learnt) faltering on drawer runners I think could be its downfall
so much youtube etc for woodworking are available
I also have a stack of books
but the finer details are scarce to say the least
it does seem that fine cabinet making is a trade that will not get passed down thru generations without furniture schools and\or members of forum that are happy to pass on their knowledge
Steve
Dalboy":2v2a1wnq said:
Have I missed the Cutlery box finish Steve
yes all done and moved on :oops: I LIE BADLY
this was such a bad idea to start with...weekend warriors don't have the time for this sort of work IMHO
I am still working on it, and I will get it done
I think it may be my bad planning, but I seem to have nearly all the components ready and nothing fitted together as they have to be in order
I will make and groove the drawer slips tomorrow
a few bits of brass to cut and polish and then onto glue up
Steve
Grooves in drawer sides is worst possible option - very little bearing area reduced even further by clearance. They wear out very quickly.
drawer slips not sides
I would have preferred the sides so I don't lose too much depth to drawers
but it will be slips
Steve
talking of drawer slips :)
there seems to be 2 options
a) fitted to bottom of drawer side (making drawer side deeper and thicker)
b) fitted flush to bottom inside of drawer side (making drawer side same height but thicker)
is there a right \ wrong way?
Steve
Steve
And I will still be watching for updates Steve good job there is no turning involved as well :twisted: :twisted: :twisted: :lol: :lol: :lol:
Steve
thanks Derek
I will try to upload progress tomorrow
I did actually turn lathe on over the weekend to make some Mr Nosey spectacle stands for a SWMBO request
and the knobs will be interesting I hope (turned on lathe),as will be 7mm brass rod glued into mahogany and then thread tapped if all goes well
Steve
SteveF":26tc4tda said:
thanks Derek
Steve
What no pictures Steve :lol: :lol: :lol:
ok a few pics
Drawer slips...the bit I do not understand
which way up?
the box complete with brass corners (to hide the sliding dovetails, and holds box together)
the front of the box has false drawer at top, then there will 3 drawers below
lid still oversize
drawer box parts
all my beech was spalted, but feels solid and I wasn't going to buy more wood
drawer fronts and drawer slides, I know they are different colour but I am low on suitable pieces ( I may remake them 2 yet)
and Mr Nosey mk11
and the picture I should delete and not show...angry with myself on this mess, its less than 1mm but so visible ( I may make a new corner slightly larger)
yes the screws are chewed up, but they are just half length ones that were reused..I will replace :)
Steve
    143.6 KB
    210.7 KB
    158.5 KB
    126.8 KB
    159 KB
    205.3 KB
    230.6 KB
    201 KB
Dalboy":2muyedna said:
At least you are getting there Steve Lovely pieces of spalted wood
I m getting there slowly
it is however on hold due to lack of knoweldge
I have googled \ read books like crazy
below drawer and I have minimal rub area
inside drawer and i have a ridge
both work in desgn tbh
until I get the eureka moment.maybe time to abandon and work on mk3 Nosey
Steve
Stop over thinking it. Make it. Decide what didnt work so you can change the next one. Move on.
And the only tip I can give to improve the piece... slot head screws should face length ways down the wood, not random like pozidrives.
brass slot head screws face whatever way they want :)
if you bottom out the countersink brass to brass they wont turn anymore
Steve
If you cant get the slot to tighten in the correct place, you back it off untill its inline.
Its a finishing touch that has been forgotten since the cross heads arrived.
I will see happens when I get to that stage. I agree it would look nicer..those screws are scrap ones that are in the pic
I have a nice boxwood handled screwdriver that fits them perfect...when I find the pineapple thing
well I took your forceful advice and got on with it :D
I fitted the drawer runners and the front "rails" if that is correct terminology
I made the runners 1.5mm higher than the rails, not a clue if this is correct way to do this
my thoughts was to stop the drawers bottoms rubbing on the front rails
I will have false fronts so can reduce this height at final fit to 1mm approx
I found an article on here about drawer slips that Custard \ Jacob had commented on so all the mud is now clear
Steve
