Dovetail saw - Pax or Lie Nielsen?
profchris
14 Jun 2015
Suffolk
I might get one or the other as a present - but which?
Pax are 20 tpi, Lie Nielsen 15. Otherwise the specs are very close. And any views on rip or crosscut (I'm tending to rip if only for ease of sharpening).
I think I'd like views from those who've used them, and suggestions for any others around the same price. Can't run to a Skelton sadly, and the Veritas is too ugly for a present!
If it helps, it will be used for making ukuleles, though I might venture a dovetail some day. In any event, accurate shallow cuts are what I need it for.
Don't rule out Veritas. Before buying I thought the same as you about it's appearance but once I got over that I now enjoy using it very much, and to counter it's looks the price is very attractive.
The Pax is also available in the 15 TPI, I usually recommend buying a rip saw first, most cuts in furniture making are rip cuts.
This is a review written by my students and I a few years ago, before we sold tools or the 15 TPI was made by Pax.
http://www.peterseftonfurnitureschool.c ... icle57.pdf
Cheers Peter
I have a Pax 10" 15tpi bought through Peter and its a fantastic little saw. My only criticism is that the handle is quite large but other than that its very good.
Matt
I own the LN and I've bleated on about LN before - they just do it for me. LN take tried and tested designs and just make them better. LN always win hands down on the looks front (maybe that's the traditionalist in me)
The dovetail saw is lovely to look at with the open curly maple handle - simply beautiful. I could easily hang it up in the livingroom.
The Pax is a nice looking saw, however I can't compare it for performance unfortunately as I don't own one, so I'm no use to you at all. Other than the LN is a lovely saw to use and the handle fits my hand like it was moulded from it (I have big hands). I thought about buying the tapered version, but stuck with the standard blade.
Jonny
Hi. I have the Pax 1776 Dovetail (Peter's verson) and apart from its obvious aesthetic appeal, I find it great to use - just the right feel and weight. Can't say I have compared it with the LN though. I'm sure either would be a great gift but I would rather support Sheffield-made given the choice and all things being fairly equal.
Richard
I have a 15tpi Pax and like it a lot. Even though it's filed rip the teeth are fine enough that you can crosscut with it as well, which I do a lot for the end of dovetails or small tenon shoulders. The sharpening job on it when it came was also nothing short of astounding, the saw seemed to almost be sucked into the wood.
Whilst it will come down to personal preference I went with the Pax because it is heavier and has a larger handle (I have played with the LN offering in an shop). I think they are both handsome tools but the folded brass back really made the Pax stand out for me.
Have you considered Skelton Saws? For me it's got a better weight and you can get the handle made for your hand. I don't own one, but tried them at the fairs.
skeltonsaws.co.uk
The Pax saws are really nice...
Which Pax dovetail saw are you looking at... the Maple 1776 or the beech handled version?
I have a Pax (among other things). What I actually use now though is a Veritas. Pax looks better. Veritas quicker and easier to use and very light in the hand. I would not worry too much - you will be happy with any quality saw.
Actually thinking about it, a lot of the time now I use one of the Japanese pull saws hung on a magnetic rack behind my main bench. Super fine cut. I reach for them because they are handly and the other saws are kept in drawers.
How a saw cuts is completely down to how it's been sharpened; sorry to mention the s**** word.
Dovetails are rip cut, and you need about 4 teeth minimum in the cut to have a nice cut, this allows you to determine the minimum number of points per inch you need (PPI) for most applications, apart from stuff less than say 6mm or 1/4", 14PPI is about right. The higher the PPI the slower the saw will cut.
The smoothness of the cut face is for a dovetails determined by the amount of set on the teeth. You need almost none for dovetails as the cut in not very deep. IMO the reason to have a dovetail saw is to have a saw with the absolute minimum of set, it's the only real differentiator to it being a tennon saw.
When sawing you should let the weight of the saw do the work, and you just pull and push guiding the blade and don't press down on the blade. For harder woods you need a saw with a heavy brass back. A lighter saw can result in you adding downward pressure to keep the saw cutting. Doing this results in you having less control over the blade and cutting less accurately.
The Veritas saw is a lovely saw, but much lighter than the Pax or LN. The Skeltel saw is heavier IMO than any of the aforementioned, and is more akin to the 'old saws'. A heavy saw is just as happy cutting softwood as hardwood. The only time the weight becomes a problem is on very thin stuff, where the saw can then due to its weight cut too aggressively. Most people for stuff below 1/4" look at using a Gentlemans saw.
The 'blow out' on the backs of the cuts in the article highlighted is in my opinion solely down to amount of set on the teeth. The PAX saw with the highest number of teeth will have less set. It's very difficult to put much set on such small teeth. Most manufactured saws have more set than you need for dovetails, and the higher the PPI acts to limit the extent of the set applied. I can for instance get a saw with say 14PPI to cut with no discernible difference to one with 20PPI, however it will cut significantly faster.
Cutting at a good rate is important as again, if the rate of progress is too slow, the tendency is to weight the blade to make it go faster. Equally as the blade becomes dull, the speed of cut slows, which is more noticeable on a saw with a higher PPI.
So the thickness of the blade, the weight of the spine and the hang angle of the handle are completly without influence?
What about the rake? Don't a few moe degree rake make the cut smoother?
15 TPI is a bit easier on the eyes in respect of sharpening. For Ukulele's I suspect that a X-cut would be a little more appropriate but you will be OK with a rip. Unlike dovetails there aren't many places where the cut is the final finished cut or joint.
The Veritas is light in weight but it's a good saw if you can get past it's modern looks. It comes sharper than any new saw that I've ever bought save perhaps the odd Japanese type. I also have an older Pax, Roberts and Lee plus a vintage Groves. The Groves fits my hand and feels the best but it has a thicker plate. The Pax, the Roberts and Lee are very fine teeth. I tend to use the Veritas because it's sharp, largely because it's a bit easier to sharpen than my other saws at 20 TPI.
I have a rip and Xcut Veritas saw for dovetails and cross grain cuts. I think these are excellent and a good price now Axi have reduced the price. I have had them for about 5 yrs I think and tested against Ln and PAX before buying.
I also use a suite of japanese saws which for sma;ller box type dovetails are excellent.
Al
I haven't used a pax but I can speak well of the Lie Neilson, mine is a joy to use.
Mike.
I have a LN 15t dovetail saw, which is beautiful to look at but in truth I don't find the handle all that comfortable and a bit small. It may well suit you - I am willing to part with it too, it has seen very little use, box etc, PM me if interested - anyway I also have 2 Pax saws: not the open handled 1776 but the beech closed handle 13t/12" rip and a 15t/10" cross and I really like them. The steel is good, they have a fine folded back (can re-tension/straighten) but the handles are a little clunky. But there is loads of wood to cut into to refine (which I haven't got round to doing yet). The real clincher for these, for me, is that they share the hand sharpened plate & brass spine of the 1776 but are around £30 cheaper. The 12" carcass was less than £90 new. Bargain. The 1776 handle could/should be more refined for the extra cost in my opinion. Not that this would stop me from buying one if I was set on an open handle and I prefer these to the LN shape.
Thanks to all for your help. I've ended up choosing the Pax 1776 and it's sitting in its box as I type. Reasons: Good comments about its usability, it *looks* like a present (important for the giver!), and perhaps some sentimentality about UK manufacture and the traditional techniques.
I can't look at it yet because my birthday is next week. I'll post some comments once I've had time to play with it.
Good choice :) No biased here obvs =D> =D> =D>
Thank you for supporting us, our saws and of course, Great British manufacturing....
Please also feel free to come to our Sheffield Tool Event the Kelham Island Museum - 11th Sept 11am-4pm. Meet the makers of your saws!
Our products along with other Sheffield makers are being sold here. Also behind the scenes tours of the Hawley tool collection are bookable.
More info on our facebook page.
