TrimTheKing
Good evening all
apologies in advance for the length of post, but I wanted to make sure I got as much info in as possible up front.
I am calling on your collective good nature to help me with an issue that, even after much beard scratching, I am having trouble getting my head around.
I have recently moved into a new house and have a nice size garage (6x5 metres) that I want to turn into a workshop. The problem I am having is the doors. I will explain as best I can, and the pics will hopefully help.
Currently the doors sit within the frame, but open both in and outwards so I am having problems working out the best way to seal them up before I go putting any machines in there as rain get blown in around the edges at the moment.
Pic #1 - This is the doors from the outside. The two middle doors are hinged internally and open inwards, and can then hook to the back of the outer doors. The outer doors are hinged externally and can swing outwards and hook to the walls giving the full opening.
Click on image for larger view
Pic #2 - This is the doors from the inside, showing the door opening orientations.
Pic #3 - This is a closer view of the doors and shows how there is no jamb as such and the doors just swing freely in the opening.
You know the drill by now
What I want to do it come up with some way that I can create a kind of jamb (I guess!?!), that when closed, all the doors will sit tight up against to stop draughts and rain ingress, but still allow the doors to open in their correct orientation.
Hopefully that ramble makes sense, if not please let me know and I will try and articulate a little better. More pics available/possible if required.
Cheers in advance for your help
Mark
PS The crude run offs at the bottom of the doors were a temporary measure to try and get the rain to drip away from the door. These will be replaced with a much nicer, properly fitted set once I am up and running.
![](https://proxy.imagearchive.com/b68/b68294aca24794838e75a9055d7b180b.jpg)
![](https://proxy.imagearchive.com/fac/facd540f9cfd3f4d8b83e3514a6e1a1f.jpg)
![](https://proxy.imagearchive.com/601/6019350ddca05760a701067f55b32c67.jpg)
Mark
