SPinonit
I have two doors that need the seals replacing. One of the doors is the back door, leading out of the kitchen and the seal is a fairly large black affair. It is quite rubbery - almost as if it is circular.
The other is on our external garage door and has been painted over by the idiots who built the house #-o . They identified themselves as fully qualified idiots when originally they forgot to put a door into the garage, so I had to demand they retrofit one. They cut the brickwork away and removed halves of bricks from every other course so they could instal the frame/door. In doing so, they made a complete mess of everything and the door never fit and shut properly. After 5 years I'm feeling the need to sort it out properly so that it is more in keeping with the home workshop I'm trying to create. The seal in this door is a buff coloured v-shaped plastic - or at least it would be if the idiots hadn't painted it :sign3: . As they did paint it, it is hard and prevents the door from closing. I could try to add photos if it helps, but I'm hoping this is a very easy question for someone.
[after all that :roll: ] My question is: what are these seals called and can they be bought and installed seperately (as spare parts)?
