tersan
Hello all. I don't post on this site very often but i visit it everyday and am very grateful for the posts that you all make,they have been invaluable. I have only been scroll sawing since May and started with a proxon, i now have a Delta 40-540 it's old but i have been very pleased with some of the work i manage to turn out,( even with the vibration lol ) the problem i have is with regard to the bottom blade clamping system, some of you may be familiar with this model ( at least i hope so ! ) changing the blade involves using a clamping tool which is a long bar and attached to the bar is an allen key, the bar is inserted to line up the allen key which in turn goes into the allen key type bolt there by releasing or tightening the blade, the allen key type bolt then passes through a flat square face plate and tightens on to a square nut on the otherside , the blade is then held in place between the face plate and the square nut, my problem is, this, the threads on this nut have become worn and i can no longer tighten into it. I have tried to find a replacement nut but without success so far,have emailed Delta usa but no response, is there any other method i could use for clamping the bottom blade? sorry to waffle on, but it's not easy to explain the problem without a picture, and i don't have a camera, appreciate any advice you can give,thank you. :?
