Quantcast
Dark ercol advice needed please!
Susu10
New member
18 Oct 2020
UK
Hi, I made a massive error in judgement of my pumpkin placement...I forgot to move it off of my dark wood ercol unit and subsequently it started to die and release pumpkin juice onto the side board. There is a cloudy mark where it was sat, I want to try to get rid of the mark without having to sand down the unit. I have left mayo on it overnight, tried beeswax. I am thinking of trying the iron route next? Would a stain remover help? This is a family unit and it’s aiming to be sold so I need to get this right. Any help & advice would be massively appreciated 😬
mrpercysnodgrass
29 Apr 2012
Lingen Herefordshire
There are a few routes you could go down.
Polishers reviver, there are lots of brands out there, I have never used a commercial one I make my own but Liberon products are always good. https://www.amazon.co.uk/Liberon-RINGR125-125ml-Ring-Remover/dp/B004Z4V5LA
Konig do ethyl acetate in a spray can that works very well on one pack finishes. Clean the surface, spray a fine mist over the stain and leave for at least one hour and repeat if necessary. Moisture Bloom Eliminator
An old trick is to get some greaseproof paper and a clothes iron. Place the paper over the stain and with the iron set to the wool setting iron over the stain using a light and quick circular motion. Check frequently to see if anything is happening, if nothing happens after 40 seconds or so it probably will not.
Hope this helps
Susu10
New member
18 Oct 2020
UK
Thank you. I’ll try the iron today and order the products if it doesn’t help.. thanks so much!
