Mollyrockers
New member
Hi, I’ve had an incident with a bit extension and a milling cutter in, forgot to decrease speed, I assume it threw a wobble and hit into the slab I was intending to cut (only 3mm depth of cut was set) The router nut broke in two and the cutter plus extension fell out.
Replaced with new nut and new half inch collet but still throwing a wobble (on bottom speed).
How do I know if it is the bearings or armature shaft that need replacing, can’t feel any bearing movement when a cutter is in.
Any advice/help would be greatly appreciated.
Regards,
Mollyrockers
Regards,
Mollyrockers
