Dado's
wizer
3 Mar 2005
No, it's not another Dado cutter thread.
Im 'knocking up' a couple of quick and dirty bedside tables to 'dress' a room. I just want to make a basic box with a shelf in the middle. I'm going to use the router to make the dados with 2 clamps either side of the router base and a straight cutter.
How deep should the dados be? and, when using 18mm MDF, how wide should the dados be? exactly 18mm?
Any other comments on this would be greatly apprecieated.
Adam
10 Sep 2003
UK
The shelf is 18mm - are the walls as well?
Are you stopping "short" of the front so the groove isn't visible on the shelf? Or straight through?
I'd make the slot 1/3 of the width of the wall personally, although no doubt someone will be along soon with the official "always this percentage" recommendation.
How are you fixing the whole carcass? Glue? Screws? Dowels? Plugs?
Before asking if they should be 18mm wide, I'd go and measure the width of the MDF with a vernier - it could easily be off thickness itself.
Adam
LyNx
27 Jul 2005
swindon
why dado it, why not just biscuit the shelves
Andy
wizer
3 Mar 2005
sides, shelf, top and bottom all 18mm mdf, back probably thin hardboard or mdf
I was going to use biscuits on the top and bottom joints, I guess to make life easier I could use biscuits for the shelf but not sure how strong this would be.
LyNx
27 Jul 2005
swindon
as long as no-one is going to stand on them, then i think they should be very strong for what you need
Andy
wizer
3 Mar 2005
thanks, that saved some work and a headache
Adam
10 Sep 2003
UK
Have you got a biscuit jointer? That situation is the only time you can't use a router mounted biscuit slot cutter.
Adam
wizer
3 Mar 2005
Adam
yep, i take it the fence needs removing for the shelf
LyNx
27 Jul 2005
swindon
best option, remove the fence. align the shelf on the end panel at the required height and clamp the boards together. This then gives you the stop for both sets of biscuit cuts. Easy and fast
Will add a drawing once home if needed
Or you can use magic wires. Just groove the shelf and drill two holes for the wires, you then just slide the shelf on. I can send you some if you want in return for the magazine
Andy
LyNx
27 Jul 2005
swindon
Magic wires, not sure if real name but this is them...
The ones we use now are slightly thicker than these type.
Andy
dedee
24 Jul 2003
14860, France
Andy,
you're "magic wires" are very interesting. I've googled around a bit & can't find them. Where did they come from?
Andy
dedee
24 Jul 2003
14860, France
Thanks, Woodfit's website has improved alot since I was last there.
Andy
tim
5 Nov 2004
Herefordshire
D'you think? It must have been truly terrible before. I nearly tore my hair out yesterday using it - that single drop down option which you then have to scroll through EVERY time is such a pain.
Tim
dedee
24 Jul 2003
14860, France
Sorry Tim, last time I was there it was not even possible to order on-line
Andy
