I've recently bought the Veritas bar gauge set and thought it would be a good exercise to try to make a tailor made box to house it. The set consists of 8 mm diameter bars and other bits of various shapes and sizes. My initial thought is to use a router plane to cut 9 or 10 mm grooves. Given that the bars are circular in cross section, I thought that the next step would be to take a gouge to the grooves to give them a semi- circular cross section.
If a gouge is indeed the right thing to use, can anybody recommend a make, model and size? I appreciate that somebody might have a much better method of doing this than what I've just written and suggestions will be gladly accepted. I want to avoid using electric tools.
Thanks in advance.
Thanks in advance.
